2003 Mitsubishi Eclipse My cars idle at 500-600rpm and my o
2003 MITSUBISHI ECLIPSE
99,000 MILES • 4 CYL • 2WD • MANUAL
CR33P
Hello, i have Mitsubishi Eclipse rs 2003 with 2.4l standart, i have problem with my idle the cars only idle at 500-600rpm and my oil lamp is on they remove when i go more them 2000 Rpm any1 can help me ? thanks
Michael
Mar 19, 2009 at 4:29 PM
Check the idle air control valve/motor/controller and the throttle position sensor.
Mar 19, 2009 at 4:36 PM
CR33P
That problem is bad ? can affect my engine ? thanks
Mar 19, 2009 at 4:37 PM
CR33P
[quote:4f9d23c97d="Cr33p"]That problem is bad ? can destroy my engine ? thanks[/quote:4f9d23c97d]
Mar 19, 2009 at 4:48 PM
Try adjusting for a minimun air with the air screw to raise the idle follow the VECI underhood sticker
Mar 19, 2009 at 5:30 PM
CR33P
ok, thanks very helpful forum and members ! :)
Mar 19, 2009 at 5:33 PM
