2003 Mitsubishi Eclipse LOSS OF POWER AND CAR WONT ACCELARA
2003 MITSUBISHI ECLIPSE
105,000 MILES • 6 CYL • FWD • MANUAL
CYBERNUTJR2
I just gout out the army and went back home and pick up my car that i had in storage for over a year. I had a friend of mines start the car every week and let the engine run for a while. When i took the car onto the highway and push the gas pedal all the way down i notice that the car wont go over 4000 rpms and when i go on a hill it loses even more power. Not even at a lower gear it wont accelarate past 4000. It accelarates sluggish and slow. I had a code tester plug to my car to see if any codes pop up and it doesnt. The code tester says thats everything in my car is in good shape and every sensor is working properly. I put a bottler of heet into the car to see if that help and still nuthing. Does anybody have any clue what might be wrong with my car. Any answer is apreciated.
Sep 4, 2010 at 2:33 AM
No CEL-check these sensors out MAF, MAP and TPS sensors-try cleaning the MAF sensor with an approved electronic cleaner. Also check the exhaust for restriction
Sep 4, 2010 at 6:13 AM
