2003 Mitsubishi Eclipse Intake Manifold
100,600 MILES • 6 CYL • FWD • AUTOMATIC
JCPALMER21
I recently had a tune-up on my '03 GT Eclipse...it is a v6 and in order to change the plugs and wires the intake manifold was romoved...a new gasket was put on before replacing the manifold........at the same time i removed the resonator from the exhaust to get a deeper sound........Now when i hit 3000 rpm at idle or while driving and getting on it it whistles...is it the lack of the resonator or a leak in the intake manifold?
Apr 18, 2008 at 1:29 PM
MASTERTECHTIM
  • 4,750 POSTS
i bet its the intake manifold leaking. try spraying carb cleaner at the base of the intake and see if that will change the idle. if it does then its leaking
Apr 18, 2008 at 1:33 PM
