2003 Mitsubishi Eclipse fuel pump
87,000 MILES • 6 CYL • FWD • MANUAL
ECLIPSE307
my car was running then the check engine light went on and for about ten minutes it ran bad and after i got home my car wouldnt start anymore. when it ran bad there was rough idling and when it wouldt turn on you cant hear the fuel pump work do you think its my fuel pump.
Mar 8, 2009 at 11:26 AM
  • 75,988 POSTS
Check fuse no. 24 15amp and fuse no.17 7.5 amp, and test the fuel pump relays.
Mar 8, 2009 at 11:32 AM
