2003 Mitsubishi Eclipse FRONT ROTOR
90,000 MILES • 4 CYL • FWD • AUTOMATIC
BREYMONT
NEED TO REPLACE. THIS SHOULD COME OFF EASY SINCE I BELIEVE IT IS SEPERATE FROM THE FRONT HUB AND IS ONLY HELD IN PLACE BY THE WHEEL, LUG NUTS AND CALIPER?
SHOULD A NEW ROTOR BE GIVEN A LIGHT CUT ON A BRAKE LATHE OR IS THAT NECESSARY?
Jun 8, 2008 at 4:21 AM
BREYMONT
[quote:baeb239a24="breymont"]Brakes problem
2003 Mitsubishi Eclipse 4 cyl Front Wheel Drive Automatic 90000 miles
SHOULD A NEW ROTOR BE GIVEN A LIGHT CUT ON A BRAKE LATHE OR IS THAT NECESSARY?[/quote:baeb239a24]
Jun 8, 2008 at 4:22 AM
