2003 Mitsubishi Eclipse Floor of the Car is wet.
CAR123
Air Conditioning problem
2003 Mitsubishi Eclipse 4 cyl Manual 85000 miles
There is water all over the driver side floor of my car. I took it to a shop and the a/c line was cleaned, i turned on the a/c again and it is still leaking. What is the problem? can you please help
Feb 5, 2008 at 7:42 AM
TURBOMITSU
  • 6 POSTS
have you had the master cylinder checked? on my 98 gst it would leak out on the driver side floor
Feb 19, 2008 at 8:32 AM
THIS IS MIKE
  • 686 POSTS
Check your heater hoses and heater core under the dash. They may be cracked or leaking.
Feb 22, 2008 at 4:08 AM
