2003 Mitsubishi Eclipse Clutch went to floor
2003 MITSUBISHI ECLIPSE
60,000 MILES • 4 CYL • 2WD • MANUAL
JCS528
This morning I was pulling into a parking lot and my clutch suddenly went all the way to the floor. I was able to drive around and find a parking spot, but it stalled out as I was parking. I was able to restart it.
Does this sound like a fluid leak or does the clutch need to be replaced?
How much should a leak repair cost? Or a clutch replacement?
Jul 7, 2008 at 11:54 AM
DOCFIXIT
  • 18,828 POSTS
Clutch master or slave cylinder failure. Check clutch master for fluid if none add brake see if you get pedal.
Jul 7, 2008 at 12:05 PM
