2003 Mitsubishi Eclipse 2003 Eclipse A/C problem
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROBERT JAMES
I have a 2003 Mitsubishi Eclipse V6 GT. If its hot outside or if I drive at an accelerated speed the A/C will all of a sudden blow hot air. If you stop and restart it'll blow cold again. When this happens the A/C Speed/On/Off dial has a green light on it, and when the A/C is working good, the light stays green, and when the A/C starts blowing hot, it will blink.
Please advise, thanks
Jul 20, 2009 at 3:50 PM
KIPPERMAN
This happened to me 3 years ago
2003 Mitsubishi eclipse spyder GTS manual 6-cyl. it got worse and worse and finally died completely. they had to replace the WHOLE ac system. like 2 grand.
now, its starting to happen to me AGAIN!!!.
I would really like to find out what the problem is. let me know if you figure it out.
-Scott
Aug 19, 2009 at 5:05 AM
