2003 Mitsubishi Eclipse
JCCJLEGC
Engine Mechanical problem
2003 Mitsubishi Eclipse 4 cyl Front Wheel Drive Manual
the car was running fine, shut it off over night , when i went to start it the next day it would not start , it cranks fine its getting gas and acts like it wants to fire but wont , HELP PLEASE .
Mar 2, 2010 at 10:24 AM
  • 75,988 POSTS
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 2, 2010 at 10:32 AM
