2003 Mitsubishi Eclipse
BLUE ANGEL
  • 8 POSTS
Engine Performance problem
2003 Mitsubishi Eclipse 4 cyl Front Wheel Drive Automatic
It has a code po171, system too lean bank 1 what do I replace to fix this
Aug 26, 2009 at 2:11 PM
  • 110,248 POSTS
It sounds like you have a vaccuum leak. Listen for a sucking sound, try to locate it then repair it. Most likley a hose loose. If no problems are found, I would move to the O2 sensor for bank 1. However, I do feel it is a vacum leak.
Let me know what you find.
Aug 26, 2009 at 2:45 PM
