2002 Mitsubishi Eclipse wont start
RBARBOZA10
Engine Mechanical problem
2002 Mitsubishi Eclipse 4 cyl Front Wheel Drive Automatic
when i was on my way home yesterday my car de-accelerated and idled wierd and died, fuel was getting to the spark plugs but it woudlnt start, i towed it hoime and took the spark plugs out, and let it air dry, tried it again and the same thing happened,
Mar 15, 2010 at 9:08 AM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/COP/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 15, 2010 at 9:23 AM
