2002 Mitsubishi Eclipse Transmission maybe?
MALBELL
2002 Mitsubishi Eclipse 6 cyl 74557 miles
Took a left turn and my car stopped moving. Car was still running. I turned the car off and it started again put the car in drive pressed on the gas I can rev the engine but the car doesn't move.
Feb 25, 2009 at 12:45 PM
  • 31,937 POSTS
Hi there, this is sounding like a transmission problem or a drive shaft failure, either way you will need to get a mechanic to inspect this for you as if it is a transmission problem the repairs will be beyond the average home mechanic to take on.
mark (mhpautos)
Feb 25, 2009 at 6:01 PM
FMA1
i had the same problem when i turned left my car stopped working. if you got it fix could you tell me what was the problem
thanks
Jun 3, 2009 at 6:52 PM
