2002 Mitsubishi Eclipse starter location
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
MARK BOWMAN
need to know where the starter is located
Oct 24, 2009 at 4:53 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The starter is located right above where muffler connects to the engine on the front side of the engine ( if you are looking at it from under the car). if you still can't locate it just follow the big positive battery cable down through engine compartment, it leads straight to starter.
Oct 24, 2009 at 7:05 AM
