2002 Mitsubishi Eclipse replaced egr valve
2002 MITSUBISHI ECLIPSE
SUEZK
Engine Performance problem
2002 Mitsubishi Eclipse 6 cyl Front Wheel Drive Manual
check engine light on- reading said need egr valve replaced-- replaced
Question: will light go out when cycle completes next time or should i reset it?
Oct 16, 2008 at 11:22 AM
2CARPRO JACK
  • 11,533 POSTS
I would clear the codes. That way if there is a problem, it will set fresh codews and you will know that they are new instead of leftovers
Oct 16, 2008 at 5:04 PM
