2002 Mitsubishi Eclipse oil light flickers on
58,000 MILES • 4 CYL • 2WD • AUTOMATIC
CANGEL1019
i have a 2002 mit eclipse, my problem is the oil light flickers on when i put my foot on the break only. When I start to drive the little oil can shuts off. I am not due for an oil change, i just had one a month ago.
Jul 11, 2008 at 11:26 PM
DOCHAGERTY
  • 9,606 POSTS
When confronted with problems like this, I usually try to start with the easy stuff first. You just changed the oil a month ago so was there anything different happening there? Did you use a different oil or filter? I have seen oil pressure sending units fail and send false information, the sender might be bad and if it is try replacement and/or remove the sender and check the oil pressure with an oil pressure gauge, it should not go below about 7-10 psi with the engine at operating temperature and at an idle.
Jul 12, 2008 at 12:30 AM
