2002 Mitsubishi Eclipse O2 Sensor Failures
2002 MITSUBISHI ECLIPSE
85,000 MILES • 6 CYL • FWD • AUTOMATIC
BPHAWKPILOT83
The check engine light continues to illuminate with error codes stating that both of my O2 Sensors have failed. I have replaced both sensors, one of them twice now and the codes still pop up after being reset with a diagnostic computer. Checked the connections and traced the wires as far back as I could and checked the fuse boxes under the hood and on the side of the dashboard. Any idea what else may be causing this?
Jul 28, 2010 at 11:25 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Can i have the exact codes that were set, this will be a help in the diagnosis.
Thanks, mark (mhpautos)
Jul 28, 2010 at 2:19 PM
