2002 Mitsubishi Eclipse my car wont start
10,200 MILES • 6 CYL • FWD • MANUAL
WASALAKCAG
i have a question about my car. i have 2002 mitsubishi eclipse spyder. my car wont start, i already check my battery, starter, and alternator and theyre working just fine. but when i start my car, it wont start. and if i start it therse no crank sound. its just quite, but the baterry is fine..can u help me ?
Oct 5, 2008 at 7:23 PM
2CARPRO JACK
  • 11,533 POSTS
Check for 12 volts at the small wire on the starter with key in crank position. If it has power then the starter needs to be replaced. If none, then check the clutch switch mounted on the pedal assembly.Should have power on one side, then the other when the clutch is pushed in
Oct 6, 2008 at 1:13 AM
WASALAKCAG
so you think is the starter sir. but sometimes it start but you have to start the car a lot of times to start. and if you start the car there's no crank sound its just quite, you couldn't even hear a click sound. but there's power.
Oct 6, 2008 at 10:18 AM
2CARPRO JACK
  • 11,533 POSTS
If there is 12 volts at the small wire,and it doesnt start, the starter is bad
Oct 6, 2008 at 12:02 PM
REAPER1992
  • 39 POSTS
One of my coworkers his vehicle does same thing you are explaining and its his starter idk if that helpa but i really would test the starter if you take it to a autozone around you they can test the starter for free
Apr 1, 2018 at 12:30 PM
KHLOW2008
  • 41,812 POSTS
When it fails to crank, get something to tap the starter and try cranking. If it works, time to replace the starter motor.
Apr 2, 2018 at 7:02 PM
