2002 Mitsubishi Eclipse Loud squeling oise
129,000 MILES • 4 CYL • 2WD • AUTOMATIC
PCAMPO
When I start my car after its been sitting in the heat it makes a very loud squeling noise and it does the same with the AC turned on. It stops after about 10-15 seconds. If the car is in the garage all night and I start it with the AC off it dont do it but if I turned it on it would squel for a few seconds.
Aug 30, 2010 at 11:52 PM
LEGITIMATE007
  • 5,121 POSTS
could be one of two things, either the pulley from the a/c is bad or the belt itself is bad, I would start by replacing the belt(serpentine) and take it from there
Aug 31, 2010 at 1:15 AM
PCAMPO
thanks so much! Ill try those things.
Sep 14, 2010 at 3:28 AM
LEGITIMATE007
  • 5,121 POSTS
your very welcome, keep in touch. use us whenever need be
Sep 14, 2010 at 3:36 AM
