2002 Mitsubishi Eclipse it will not start
LISA FARMER
Computer problem
2002 Mitsubishi Eclipse 4 cyl Front Wheel Drive Automatic
i was driving down the hwy the other night and my car stoped it acted like it ran out of gas i pulled over to the side of the hwy and tried to start my car again and it would turn over but not start all of the lights and nioses still worked so we know it wasnt the battery we pulled it home and we still cant start it and it has gas in it.
Apr 11, 2010 at 12:20 PM
  • 75,988 POSTS
Did you have a check engine light come on or has flashed prior to this problem and when was your last tune-up?
Do below to determine whether it's fuel or spark issue:
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Apr 11, 2010 at 12:23 PM
