ignition coil
GETECLIPSED
Engine Mechanical problem 4 cyl Front Wheel Drive Manual 145000 miles
My car has been burning up ignition coils and I cannot seem to find out why! The same coil keeps burning up over the #2 cylinder, the ignition coil over the #4 cylinder remains good and never goes bad. What would make the ignition coil over the #2 cylinder to continue to keep going bad?!
I replaced it with a brand new ignition coil every time. And usually its goes down to running on 3 cyl but sometimes it runs on 2 cyl, I guess it depends on how hot or swollen the coil gets? I install a new ignition coil and it gets hot rather quickly and swells up too causing it to burn up. And yes I have replaced spark plugs and wires several times but nothing changed, just keeps burning up coils! Any ideas!
Oct 18, 2010 at 7:24 PM
  • 55,721 POSTS
What happens is the coil driver for the #2 ignition coil is stuck on causing the coil to not work get hot and burn out. You must replace the ECM with a new or used unit to fix the problem.
Here is the ECM location you will need to have a shop program it for you.
Cheers, Ken
Dec 18, 2017 at 7:10 AM
