2002 Mitsubishi Eclipse crank shaft position sensor
75,000 MILES • 4 CYL • FWD • MANUAL
CASSBERNIER
where is the crank position sensor located on a 2002 mitsubishi eclepse 4 cyl?
Mar 14, 2009 at 6:07 AM
MONTY STEPHENS
  • 79 POSTS
Its on the end of the crankshaft, passenger side of the car, behind the main pulley.. You have to take off the left front wheel and the plastic timing chain cover to see it (and the main pully).
Once you do that, you'll see it.
Mar 23, 2009 at 3:59 AM
