2002 Mitsubishi Eclipse Car Cranks but Does not Start
108,000 MILES • 4 CYL • FWD • AUTOMATIC
DAGILLMORES
I have already had to replace the Head on the original engine. I also have check engine light on and the code points to the EGR valve not functioning properly. Now the engine will crank and you can hear it and it just wont start. A good friend who is a mechanic tried a risky but effective test in pouring fuel directly into the engine thru the throttle body and the car started and then shut off when the fuel was expended.
I was informed that the Fuel Pressure Regulator can cause this in the eclipses, is this true?
Could the EGR Valve have anything to do with the engine not starting?
Jul 11, 2008 at 9:14 PM
  • 75,988 POSTS
An EGR valve leak can prevent the engine from starting due to massive vacuum leak-
Check the fuel pressure with a fuel pressure gauge designed for your fuel system make sure its within specifications-this is where we start
Jul 11, 2008 at 9:45 PM
DAGILLMORES
I was just wanting to know if you have pictures that I can see to determine which is my EGR and also which is my fuel pressure regulator on my 2002 mitsu eclipse rs(2.4L). I cannot find a repair manual locally for my vehicle. They say that it has come out yet.
Jul 21, 2008 at 3:06 PM
  • 75,988 POSTS
You can download your manual here. See below for EGR and for t
https://images.2carpros.com/forum/automotive_pictures/12900_egr_1.jpg
he fuel pressure regulator should be on the fuel rail end-
Jul 21, 2008 at 7:58 PM
