2001 Mitsubishi Eclipse valve cover
94,328 MILES • 6 CYL • FWD • AUTOMATIC
JJOHNSON0267
  • 5 POSTS
hi, my valve cover gasket is leaking oil and i need to replace it but was told that i need a special tool to measure how tight to put the bolts on. what is this tool?
Dec 28, 2009 at 1:32 PM
OBXAUTOMEDIC
  • 3,717 POSTS
The tool is called a Torque Wrench and you can most likely rent one from your local rental store.
If you give me the sub-model and engine size in liters I will post the torq specs. I am sure you will need the wrench in Inch Pounds.
Dec 28, 2009 at 1:41 PM
JJOHNSON0267
  • 5 POSTS
i have the gt with a 3.0 v6. thank you very much.
Dec 29, 2009 at 4:04 AM
OBXAUTOMEDIC
  • 3,717 POSTS
The torq specs are 26 - 35 inch pounds
Dec 29, 2009 at 5:55 AM
JJOHNSON0267
  • 5 POSTS
thanks. and do the rubber things just come off or is there a special way to get them off because i tried pulling them but they wont come off? sorry i dont know much about cars
Dec 29, 2009 at 8:21 AM
OBXAUTOMEDIC
  • 3,717 POSTS
If they are the original then they are probably hard and will be hard to get out. So if they break up getting them out don't worry.
Dec 29, 2009 at 12:00 PM
JJOHNSON0267
  • 5 POSTS
okay thanks. ill try it out whenever i get that tool.
Dec 29, 2009 at 2:42 PM
