2001 Mitsubishi Eclipse transmission
131,239 MILES • 6 CYL • FWD • AUTOMATIC
MOSESR
I have a 2001 mitsubishi eclipse 3.0L v6 automatic and while driving the nuetral light started blinking and car wouldn't pull. When you put it into any gear the car does not move. Wondering if its the transmission and how much it would cost to rebiuld the transmission.
Jul 29, 2008 at 10:22 PM
  • 31,937 POSTS
Hi there,
first thing to do is get any codes extracted and read, a transmission re build may not be required depending on what the fault is, the price of a trans re build will vary considerably depending on the components require and a realistic estimate can only be made when the extent of any damage is known.
mark (mhpautos)
Jul 30, 2008 at 12:21 AM
