Thermostat Housing leaking?
2001 MITSUBISHI ECLIPSE
130,000 MILES • 4 CYL • FWD • AUTOMATIC
DWOODYS
Thermostat Housing leaking anti-freeze? What does this mean?
Mar 12, 2010 at 9:35 AM
NEFI154
  • 9 POSTS
the metal might have warped due to whatever reason. try simply changing the gasket or using some silicone.
Oct 20, 2010 at 4:47 AM
DAVIDPLETKA
Engine Cooling problem
2001 Mitsubishi Eclipse 6 cyl Two Wheel Drive Automatic
Where is the thermostat located on a 2001 Mitsubishi Eclipse GT V6 and is it easy to get to?
Aug 12, 2019 at 12:52 PM (Merged)
https://images.2carpros.com/forum/automotive_pictures/12900_stat_9.jpg
Removal service point <> radiator lower hose disconnection Place mating marks on the radiator lower hose and hose clamp before disconnection.
JB49
The engine was running very hot I replaced the thermostat. Now the engine runs very cool and I get no heat. Have I done something wrong?
BLUELIGHTNIN6
  • 16,542 POSTS
sounds like you installed thermostat backwards..ensure thermostat is installed correctly like picture below
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1359.jpg
this guide will help https://www.2carpros.com/articles/replace-thermostat Please run down this guide and report back.
NAKIA64
Where is the Thermostat located on a 2000 mitsubishi eclipse. I think its near the back by the battery but not sure.
Thanks
MRMIKIE
Your car has two radiator hoses, upper and lower. Follow the upper hose to the engine. The housing the hose is connected to houses the thermostat inside. Remove the hose and you will see some bolts on that housing, take those off and you should be able to get to the thermostat. Just remember to get a new gasket too.
LISA KERANS
2000 Mitsubishi Eclipse 4 cyl Automatic
where is the thermostat located and the heater core?
BLACKOP555
  • 10,386 POSTS
thermostat is located in the thermostat housing where the upper radiator hose meets the engine,
the heater core is located under the dash in the air ducts.
