2001 Mitsubishi Eclipse Rough idling
99,000 MILES • 4 CYL • FWD • AUTOMATIC
SUBWAY7
Hi my car has has a check engine light on before and it goes away. What it does is it won't move very fast and the tacometer clicks at 0-500rpms. Then when that goes away for a while, when the car is stopped it idles very low like it's going to stall and it resets my stereo and my clock and it idles rough for a few days and goes away. I've replaced the coils plugs wires air filter, and ran fuel injector cleaner through it. Nothing is working. What could it be?
Aug 21, 2009 at 6:09 AM
MERLIN2021
  • 17,250 POSTS
Check grounds. All you can find, check battery and battery cables. Follow these links. Also have the codes read, Autozone does it free, post all codes here.
https://www.2carpros.com/how_to/how_to_test_alternator.htm
https://www.2carpros.com/how_to/battery.htm
Aug 21, 2009 at 6:48 AM
DOCFIXIT
  • 18,828 POSTS
Hi Think what might be happening is at Junction Block 2 where all items effected receive power. Located on left side dash,see figure, Check connections, for anything burnt/melted. Let me know Thanks for donate
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_92.jpg
Aug 21, 2009 at 6:51 AM
SUBWAY7
All grounds are good, engine code is misfire P030030. Checked all fuses and wires. nothing out of the ordinary.
Aug 23, 2009 at 5:53 AM
