2001 Mitsubishi Eclipse replacing trans
120,000 MILES • 6 CYL • FWD • MANUAL
NO REGRET
  • 5 POSTS
i am replacing the trans but the throw out bearing will not seperate this is a forward actuating clutch system i cant find any info on why it wont release
Jan 8, 2008 at 12:30 PM
  • 31,937 POSTS
Hi there, The thrust is retained by a wire clip and when removed it should slide off the nose of the gear box.
https://images.2carpros.com/forum/automotive_pictures/61395_clutch_1.jpg
I hope this helps, if more information is required please re post. Mark (mhpautos)
Jan 8, 2008 at 9:56 PM
