2001 Mitsubishi Eclipse Power Window Problem
NICKK3G
Electrical problem
2001 Mitsubishi Eclipse 4 cyl Two Wheel Drive Manual 140k miles
hey, Recently my Driver side window will not go up it is power window. The passenger side window will only go up when you use the passenger side switch.
We have replaced the Driver side switch, the fuse and the power relay and we sill have nothing.
No noise comes from the driver side window.
Apr 25, 2009 at 10:03 AM
MONTY STEPHENS
  • 79 POSTS
Sounds like power window motor.
You can pull your door panel off, then undo the plug to the motor. Stick your Ohm/volt meter prongs into the wire plug and make sure you are getting power when the switch is hit. If you are, then its time for a new motor. If not check your connections on the switch.
May 4, 2009 at 4:14 AM
