2001 Mitsubishi Eclipse oil light comes on
141,000 MILES • 4 CYL • FWD • MANUAL
JASON MOBLEY
my oil light has been coming on when i stop or leave it idleing. i have changed my oil and put oil stabilizer in it. it still continues. i had a guy check the pressure for me and at 2500 rpms it has 60 lbs but at idle 750-900 rpms it only has 7 lbs. i have listened for the lifters to chatter and not heard anything. i have no clue what to do.
Aug 11, 2009 at 2:19 PM
BLUELIGHTNIN6
  • 16,542 POSTS
oil pump is starting to fail, at idle is much harder on pump and faulty pump can't produce enough pressure at idle to lubricate system properly
Aug 11, 2009 at 2:22 PM
JASON MOBLEY
so should i replace the water pump timing belt as well as the oil pump?
Aug 11, 2009 at 2:32 PM
BLUELIGHTNIN6
  • 16,542 POSTS
timing belt or waterpump is not attached to the oil pump..but at your vehicle's mileage, it's not a bad idea to replace the timing belt.
Aug 11, 2009 at 2:36 PM
JASON MOBLEY
so what am i looking at for just the oil pump for the labor?
Aug 11, 2009 at 2:45 PM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_799.jpg
Aug 12, 2009 at 6:50 AM
