2001 Mitsubishi Eclipse No dash lights, help please
2001 MITSUBISHI ECLIPSE
106,000 MILES • 4 CYL • FWD • MANUAL
GOBBLES
My dash lights went out after not driving the car for a few days. (The lights not working are the cluster lights, the "cubby" light, and the HVAC lights. So I checked all the fuses 3 times total, once visually, and twice with a light tester.
Well to get to the point...
I have the dash apart, and the cluster in my hand. When I touch the back of the cluster(where the bulb twist ins make contact to get power) with my light tester, and flip on the headlights, I have light. Could one bad bulb cause all of these to be out? Or could I have a bad ground to my cluster?
Jul 3, 2008 at 10:16 PM
KHLOW2008
  • 41,814 POSTS
Hi gobbles,
Either the bulbs are fused or have poor contact, bad ground, the connector or its wire is bad.
Jul 5, 2008 at 3:05 AM
GOBBLES
I took the dash cluster apart. When I touch where the bulb connects, with my test light, it lights up when I turn on the headlights. When I touch the ground spots on it, they also light up, when my test light is connected to 12v.
There are three wires going into my dimmer switch. Black, black with yellow, and green with white. Green with white has power when the headlights are on. Black is always grounded, and black with yellow grounds when the headlight switched is flipped on. I changed all of the 194 bulbs out and still have no dash lights.
Jul 5, 2008 at 9:02 AM
KHLOW2008
  • 41,814 POSTS
Hi gobbles,
If equipped with brightness control, that is the one you should check.
Jul 5, 2008 at 2:06 PM
GOBBLES
You're talking about the dimmer switch? How do I check it?
Jul 5, 2008 at 2:17 PM
KHLOW2008
  • 41,814 POSTS
Hi gobbles,
I do not know how many pins there are and don't have any circuit diagrams.
Ground the wire from the meter to the dimmer switch through a test lamp and if the lights works, the dimmer switch should be faulty.
Jul 6, 2008 at 4:15 AM
GOBBLES
Hello again KHLow...
When I ground the hot wire with the headlamps/parking lights off it comes on, the rest of the time it isnt. It does the same thing without the switch hooked up.
Jul 6, 2008 at 8:17 AM
KHLOW2008
  • 41,814 POSTS
Hi gobbles,
Replace the switch if it cannot be adjusted.
Jul 7, 2008 at 1:20 AM
