HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mitsubishi
Eclipse
Engine
Crankshaft
SPONSORED LINKS
2001 Mitsubishi Eclipse newbie question
ACE_3UP
MEMBER
2001 MITSUBISHI ECLIPSE
2001 Mitsubishi Eclipse 6 cyl Front Wheel Drive
I have a 2001 mitsubishi eclipse gt and I was wondering if I was to get new camshafts if I would have to get a new crankshaft also?
Sunday, May 11th, 2008 AT 9:22 PM
BLACKOP555
MECHANIC
Most do not, but some do, it depends on the kind you get.
Ask the place your buying it from.
Most of the time when the camshaft is replaced other mods are done and the crank is replaced with it.
SPONSORED LINKS
Sunday, May 11th, 2008 AT 9:56 PM
Please
login
or
register
to post a reply.
Related Crankshaft Content
2001 Mitsubishi Eclipse Crankshaft Pulley/harmonic...
I Am Trying To Replace The Crankshaft Pulley On The 3.0 Mits Engine. It Has One Big Bolt In The Middle. Is This Threaded Normally Or...
Asked by
jholtgrieve
2001
MITSUBISHI ECLIPSE
VIDEO
Replacing the Crankshaft
Instructional repair video
Knock Sensor
How To Check Knock Sensor?
Asked by
wonderercao
1 ANSWER
1 IMAGE
2001
MITSUBISHI ECLIPSE
What Color Are The Wirers For The Maf/iat Sensor For A...
I Am Installing A G-force Performance Chip And It Saysi Will Need To Determine Which Two Wires Lead To The Maf/iat Sensor. There Are 7 Wires...
Asked by
justinmcarney
2001
MITSUBISHI ECLIPSE
Turbo Question
I Have A 01 Mitsubishi Spyder Gt 3.0l And I Want To Put A T3-t4 Turbo Kit In It, What Else Would I Have To Do To Keep The Psi From Blowing...
Asked by
travist88
1 ANSWER
2001
MITSUBISHI ECLIPSE
2001 Mitsubishi Eclipse Iac Sensor
2001 Mitsubishi Eclipse 4 Cyl Front Wheel Drive Automatic Will The Sensor Work Properly Until The Engine Reaches Operating Temp? Does...
Asked by
marty oaks
1 ANSWER
2001
MITSUBISHI ECLIPSE
VIEW MORE
SPONSORED LINKS
Clean and Crankshaft Install
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
