2001 Mitsubishi Eclipse NEUTRAL SAFETY SWITCH
TYLER_B2001
Electrical problem
2001 Mitsubishi Eclipse 4 cyl Two Wheel Drive Manual
hi i was woundering if you could tell me where the neutral safety switch would be on a 2001 mitsubishi eclipse gs
Feb 3, 2010 at 10:27 AM
  • 75,988 POSTS
2001 Mitsubishi Eclipse GS L4-2350cc 2.4L SOHC MFI CLUTCH INTERLOCK SWITCH CHECK AND ADJUSTMENT
https://images.2carpros.com/forum/automotive_pictures/12900_csm1_1.gif
1.Check to be sure that the interlock switch is as Shown in the illustration when the clutch pedal is depressed at its full stroke 130 mm (5.1 inches) . If the specified dimension is not met, loosen the clutch interlock switch 1/4 turns counterclockwise. Then slide the switch to the specified dimension, and turn the switch 1/4 turns clockwise to lock.
https://images.2carpros.com/forum/automotive_pictures/12900_csm2_1.gif
https://images.2carpros.com/forum/automotive_pictures/12900_csm3_1.gif
2.Connect an ohmmeter to the interlock switch connector, and then check for continuity when the clutch pedal is fully depressed and when it is released outward.
Feb 3, 2010 at 2:52 PM
