2001 Mitsubishi Eclipse Nasty Vibration
137,000 MILES • 4 CYL • FWD • AUTOMATIC
SHARK030267
Engine has a nasty vibration around 4000 or so rpm's. I can really feel it in my feet on the gas pedal. I've installed new NGK Iridium plugs, Bosh wires, timing belt with tensioner kit, crank and cam seals, water pump, shaft balancer belt and a new mass air flow sensor. No check engine light is on and no codes are being thrown. No vibrations when car was purchased until now.
Jul 23, 2008 at 3:41 AM
KHLOW2008
  • 41,812 POSTS
Hi shark030267,
Most probably the balancer belts have not been installed in sync.
Jul 23, 2008 at 4:18 AM
