put in battery then cd player has CODE on it won't work nor dose my ac can u help
Aug 8, 2008 at 11:40 AM
✓Experienced Mechanic
Hi there,
You will have to enter your radio security code, if you don't have it, you will have to contact your dealer as they will be able to retrieve it through there internal systems, as for the A/C get the pressures tested and have a leak test done.
