2001 Mitsubishi Eclipse engine stalls
17,500 MILES • 6 CYL • FWD • MANUAL
DANGERZONERACING
i have an Eclipse GT and when i down shift and come to a complete stop the car idles rough like it wants to keep running but alot of times it stalls at a stop but then some times i keep it in neutral and press in the clutch and put it in gear and go it dont stall could what could cause this plm i was thinking Mass air flow sensor but i cleaned it up with some mass air cleaner spray but that didn't help any soo? thanks for your input
Oct 17, 2009 at 4:59 PM
  • 75,988 POSTS
Check and test the idle air control motor, throttle position sensor, volume airflow sensor and EGR valve
Oct 17, 2009 at 7:34 PM
