2001 Mitsubishi Eclipse Engine out of time?
70,000 MILES • 4 CYL • 2WD • AUTOMATIC
MONTY STEPHENS
  • 79 POSTS
Greetings -- I changed my timing belt this weekend on my SOHC Eclipse. After I finished the car cranked and started perfectly. But now it ideles low at 500 rpm and lacks a fair amount of power. Is this a symptom that the timing itjust slightly off or should I look for another problem? -- no check engine lights are on.
Mar 16, 2009 at 12:44 AM
  • 75,988 POSTS
Did you disconnect the battery doing the repairs if so the computer has to go thru relearning process that may require 40 restarts to memorize its program
Mar 16, 2009 at 1:24 AM
