2001 Mitsubishi Eclipse engine compression in psi?????
*MR.MOTORHEAD*
Engine Performance problem
2001 Mitsubishi Eclipse 4 cyl Two Wheel Drive Automatic 0
What is the compression in psi on a 2001 eclipse in a v-6 and 4 cylender? per specs? thanks
kyle
Aug 18, 2008 at 9:03 AM
MERLIN2021
  • 17,250 POSTS
BASIC DIAGNOSTIC PROCEDURES -2001 Mitsubishi Eclipse GS
Page 1 of 1
Compression
Check engine mechanical condition with a compression gauge, vacuum gauge, or an engine analyzer. See engine analyzer manual for specific instructions.
Disconnect Crankshaft Position (CKP) sensor to disable ignition and injectors. Check engine compression with engine at normal operating temperature, all spark plugs removed and throttle wide open. See COMPRESSION SPECIFICATIONS table.
COMPRESSION PRESSURE Application Diamante Standard Minimum Eclipse, Eclipse Spyder & Galant 2.4L Standard Minimum 3.0L Standard Minimum Mirage 1.5L Standard Minimum 1.8L Standard Minimum Montero Standard Minimum Montero Sport 3.0L & 3.5L Standard Minimum Maximum Variation Between Cylinders All Models
© 2007 Mitchell Repair Information Co., LLC.
Pressure - psi (kPa)
174 (1200) 129 (890)
185 (1275) 139 (959)
119 (824) 83 (575)
187 (1290) 133 (920)
199 (1370) 151 (1040)
15 (100)
http://www.ondemand5.com/mric/common/asp/printart.aspx
8/18/2008
Aug 18, 2008 at 9:21 AM
