2001 Mitsubishi Eclipse crankshaft pulley/harmonic balancer
72,000 MILES • 6 CYL • FWD • MANUAL
JHOLTGRIEVE
I am trying to replace the crankshaft pulley on the 3.0 Mits engine. It has one big bolt in the middle. Is this threaded normally or reverse threaded? Once I get the bolt off will the pulley come right off or will I need something special to get it off? Is there a certain torque I need to put the bolt back on with?
Jan 3, 2009 at 5:15 AM
BUDDYCRAIGG
  • 2,262 POSTS
1 the bolt is normal thread.
2, there are only a hand full of cars that the balancer will just pull off.
most use a puller
3, i'm looking for the torque spec, give me a few minutes
ok, there is a foot note, to apply engine oil to the treads before installing.
torque to 131-137ft.lbs.
Jan 3, 2009 at 11:21 AM
JHOLTGRIEVE
I have tried to get the bolt loose but with no luck. Do I need an impact wrench to get it loose?
Jan 3, 2009 at 2:09 PM
BUDDYCRAIGG
  • 2,262 POSTS
the bolt is probably torqued down to about 200ft.lbs.
you can get it with a long enough breaker bar, but you have to keep the engine from turning over.
Jan 3, 2009 at 2:32 PM
JHOLTGRIEVE
How do you keep the car from turning over?
Jan 4, 2009 at 5:13 AM
BUDDYCRAIGG
  • 2,262 POSTS
take the starter off, and wedge something (like a big flat screwdriver) between the teeth of the flywheel and the bell housing of the transmission.
Jan 4, 2009 at 5:33 AM
