2001 Mitsubishi Eclipse air conditioner malfunction?
125,000 MILES • 4 CYL • FWD • MANUAL
JTODD1122
Hi, I have an issue with my ac/heater. The blower fans for the heater only work on 4, the highest setting, when i put it on 1,2,or 3 the fan doesnt work, but when on 4 or high, it does. Also when I try and use the A/C the green a/c indicator light on my switch comes on on 1,2 , and 3 but the ac fan doesnt blow. when I put it on 4, the a/c light goes out and it just blows regular air..Please help!!
Nov 17, 2009 at 4:04 AM
KHLOW2008
  • 41,812 POSTS
Hi jtodd1122,
Thank you for the donation.
When such conditions occurs, the most common fault is a bad blower motor resistor.
It could be only the blower motor or it could have a second problem with the AC turned on at maximum speed but I would suggest getting the resistor problem solved first.
Nov 18, 2009 at 4:13 AM
