2001 Mitsubishi Eclipse 01 Eclipse won't turn over unless u
TRACY22NC
2001 Mitsubishi Eclipse Automatic
Okay please bear with me, I'm a chick who knows nothing about cars, but I'm trying to outsmart my bf who thinks we can't fix his car ourselves. His car keeps cutting off then won't turn over (or stay running for more than a couple seconds) for about 1/2 hour. The computer thingy at AutoZone said something about the rear O2 sensor, but my bf changed the front sensor instead and the car drove ok for a while with check engine light coming on sometimes while idling. The other day while driving I turned on the A/C and within minutes the engine cut off while I was still driving. About a 1/2 hour later it finally turned over again. Hours later we tried to start it, but the engine wouldn't start till my bf unplugged something I *think* was the front O2 sensor. Now about 95% of the time the engine won't turn over unless he unplugs that part. Do you have any ideas that I can claim to be own?? LOL!!
Sep 14, 2010 at 3:57 AM
BMRFIXIT
  • 19,053 POSTS
if its still stalling after and or during driving and will not start until few minutes after ,have to suspect a crank position sensor
as for the O2 sensor that should not effect the starting and or stalling as it is an emission related part and engine should start and run with or with out it
if you can get the name or what is it that your BF disconnecting that should also help in telling what is going on
Sep 14, 2010 at 11:20 PM
TRACY22NC
He said he disconnected the o2 sensor and nothing more. Another forum mentioned the MAS. That a possibility?
Sep 15, 2010 at 1:48 AM
BMRFIXIT
  • 19,053 POSTS
MAF sensor will cause many problems including a no start and no power on acceleration
a wrong O2 sensor can cause many issues too
Sep 15, 2010 at 12:25 PM
