2000 Mitsubishi Eclipse wiring harness issues?
KANAKANAKA77
drivers side headlight out. tested leads of headlight on battery and it functions. I connect it to the wiring and nothing. I have tried all combinations of the 3 wires as they are color coded differently than the other side and nothing. next step?
Nov 4, 2010 at 6:02 PM
KHLOW2008
  • 41,812 POSTS
Hi kanakanaka77,
Are both the high and low beams of the headlights out?
Were the fuses checked?
Do you have battery voltage at the White/Red wire when low beams are used?
Nov 4, 2010 at 11:02 PM
KANAKANAKA77
hi there,
thanks for the response
only one headlight is out
both high and low not functioning
fuses- i thought there was only one for both headlights?
can't get voltage from said wire. what voltage should i be getting as I can't find it online?
sorry, just learning the ropes...
thanks again
Nov 5, 2010 at 5:24 AM
KHLOW2008
  • 41,812 POSTS
There are 4 fuses for the headlights, one each for right and left and high low.
You should be getting battery voltage when headlights are turned on.
In engine compartment fuse box,
Fuse # 11 is for Right Low beam
Fuse # 6 is for Right high beam.
Both are 10 A fuses.
Nov 5, 2010 at 5:48 AM
