2000 Mitsubishi Eclipse why dioes my engine die when i stop
117,000 MILES • 4 CYL • FWD • AUTOMATIC
SAM101
I recently purchased a used mitsubishi eclipse. When i bought the car the ac was leaking all over the driver side floor. I fixed that problem but now when ever i stop the RPMs drop almost to the point that the car dies and then it usually bounces up then back down a couple times before stabilizing, but sometimes it just dies. I doubt that the two problems are related. Where should i look for the cause for it dying. I would really appreciate any help any one can offer.
Aug 29, 2008 at 1:46 PM
LEGITIMATE007
  • 5,121 POSTS
I would first check the idle air control valve, and then check the mass airflow sensor.
Aug 29, 2008 at 2:49 PM
