[quote:1184d61428="eclipsemls@aol.com"]Engine Mechanical problem
2000 Mitsubishi Eclipse 6 cyl Front Wheel Drive Manual 89000 miles
Is my 2000 Mits Eclipse GT engine damaged if my timing belt broke on the 3.0 motor? is the motor an interference motor or non?[/quote:1184d61428]
Actually, the timing belt is ok it was the idle pulley bolt that broke, the pulley came off and the timing belt then jumped off the other pulleys. Because the timing belt came off, is the engine damaged?
May 20, 2020 at 3:42 AM
