2000 Mitsubishi Eclipse timing
188,560 MILES • 4 CYL • FWD • AUTOMATIC
BABBYBOYROY
i chang my timeing belt crank sensor the car runs but has no power i shot it whith timeing light the motor runs poor i check thevalve timeing it is right but the car runs at a timeing light number some wher after top dead center can you help maybe i did noyt put it in time right can you tell me how to do so
May 18, 2009 at 1:01 PM
MONTY STEPHENS
  • 79 POSTS
You must have the V6.
There is no ignition timing adjustment on the 4. Check other stuff though, vacuum leaks and let the car run through some cycles to set the computer. I did the same (repalced timing belt, car lacked power)and the pro mechanics on this site advised me to let the car run some and see if it gets its computer settings on its own. It did for me and runs good now,.
May 20, 2009 at 4:03 AM
