2000 Mitsubishi Eclipse Squealing
105,000 MILES • 4 CYL • FWD • AUTOMATIC
BGARNER
Mitsubishi Squeals when cranked cold and only in ger. I have made my carrier for over twnety years fixing cars and equipment and I cant seem to stop this for my son.
If you start this car when it is cold it is fine but as soon as you put it in gear it makes this awful squealing noise. I have replaced all belts. timing belts and the water pump. And yes a water pump can give you a squeling noise. the belts are are adjusted properly and all idlers and pulley sheaves are in good shape. Before you ask it also does this with the AC on or off. Trust me this one is not easy to find.
Any input on this would be appreciated.
Apr 23, 2009 at 9:34 AM
BMRFIXIT
  • 19,053 POSTS
Just a suggestion
you may or may not already tried it
how about removing the belts and give it a try
does the noise go away
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Apr 23, 2009 at 12:38 PM
BGARNER
Actually that is pne thing I have not tried which would only serve to prove or disprove that it is with the belts, sheaves or it's drivern attachment. I will try that.
Apr 24, 2009 at 2:00 PM
BMRFIXIT
  • 19,053 POSTS
Exactly my thinking
let me know the out come
Apr 24, 2009 at 3:03 PM
