I posted this before and was told that it could be my:
map sensor
mAf sensor
tbs sensor
ignition coil
spark plugs or wires
fuel pump or injectors
or vacuum leaks...etc
As I'm sure anyone with an eclipse knows these things aren't cheap! So if i'm interested in doing this myself how should I go about starting? There has to be a way to test these things or clean them rather than replace everything at random! I' searching these methods out online as I type this but Im curious as to the which order I should test these things for so I can at least isolate which components I really need.
Thank you
map sensor
mAf sensor
tbs sensor
ignition coil
Thank you
Dec 7, 2009 at 4:03 PM
