2000 Mitsubishi Eclipse Noiesy susppension over bumps
2000 MITSUBISHI ECLIPSE
77,000 MILES • 6 CYL • FWD • MANUAL
JOHNNYS
Hi
When I go over bumps (speed bumps/potholes) I hear a squeeky noise from the front suspension, like rusty springs of an old cauch. Repair manual says it might be inadequate lubrication but doesn't say what to lubricate. I can't find any lub fittings on the suspension arms or strut assembly.
What could it be and how do I fix it??
Jun 17, 2008 at 4:14 PM
DOCFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 18,828 POSTS
You are right, there are no zerk fittings to lube. So push on the left & right fenders do you hear the noise.
If so could be spring mounts or ball joint.
Now turn steering wheel back and forth hear niose then strut bushing/brearings bad.
Let me know
Jun 17, 2008 at 4:44 PM
JOHNNYS
When I push on the fender I hear the noise and its more like sqeezing a rubber ball, I assume its the sound the bearing boot makes??
Is this a mechanical concern or just cosmetic noise..?
Jun 24, 2008 at 3:38 PM
DOCFIXIT
  • 18,828 POSTS
If the struts have never been replaced then that is what you maybe hearing. This will effect handling and can cause tire wear. Could be ball joint and that will only get worse.
Hope this helps
Jun 25, 2008 at 6:55 AM
