Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mitsubishi
Eclipse
Engine
Symptoms
Shakes
2000 Mitsubishi Eclipse idle set
2000 MITSUBISHI ECLIPSE
84,000 MILES • 4 CYL • 2WD • AUTOMATIC
SHOCKY06
MEMBER
1 POST
How do you raise idle? The rpms are too low and car will shake when idling.
Aug 26, 2008 at 7:55 AM
DOCFIXIT
Experienced Mechanic
Idle is controled by cars computer it is not adjustable.
Have the ISC idle speed control motor checked for proper operation.
Aug 26, 2008 at 8:11 AM
2CARPRO JACK
Also try cleaning out the throttle bore with carb cleaner and a rag, this will help stabilize the idle too
Aug 29, 2008 at 12:48 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
