I installed a new battery and after that it ides so low that it stalls at every stop -- any ideas on what to do?
May 4, 2008 at 7:22 AM
MASTERTECHTIM
✓Experienced Mechanic
it will either clear up on its own after a few drive cycles(most likely) or you may have a problem with the idle air control valve. try cleaning the throttle bore and go from there.
