2000 Mitsubishi Eclipse iac valve system faul
123,000 MILES • 4 CYL • 2WD • AUTOMATIC
WILLIE8989
I but a new iac sencor and ti still give me the same code p 0505 way is that
Oct 16, 2010 at 8:59 AM
KHLOW2008
  • 41,812 POSTS
Hi willie8989,
When trouble codes are present, it does not necessarily mean a component is faulty. It could be bad wiring circuits, faulty PCM or the component is faulty.
Since you have replaced the component, the next thing you need to do is to test/check the wire circuitry and lastly the PCM if wiring does not show any fault.
Oct 19, 2010 at 2:33 AM
